drive wont go up
Old 04-26-2009 | 07:41 AM
chadman99's Avatar
Default drive wont go up
my bravo 1 drive will only go up if i use the trailer switch , checked the switch and jumped it out still nothing i do have 12 volts @the switch
chadman99 is offline
Old 04-26-2009 | 11:32 AM
You need to replace the up relay. I'm not sure of the wire colors but there are two one for up one for down.
RBeyer is offline
Old 04-26-2009 | 12:47 PM
The trim limit sender on the drive is probably bad or the wires are cracked.
Griff is offline
Old 04-27-2009 | 03:59 AM
Up is blue for sky down is green for grass.
Boat Tech is offline
Old 04-27-2009 | 06:25 AM
rchevelle71's Avatar
I believe you can switch the up and down relays, just to rule this out before buying one, if you switch them, and the problem reverses(now the down doesnt work) then it is a relay, if not most likely the sender or wiring.
rchevelle71 is offline
Old 04-27-2009 | 08:14 AM
hoozeyurdaddy's Avatar
If it goes up with the trailer switch, It's not the relay, It's something in the trim limit switch, like griff said.
larry
hoozeyurdaddy is offline
