paint over epoxy resin?
Old 04-26-2009 | 02:58 PM
Default paint over epoxy resin?
What primer and paint can i use over epoxy resin?I wanted to paint it with imron paint.Also can i use auto filler like mar glass to fill over the epoxy?
fuelcustoms is offline
Old 04-27-2009 | 11:37 PM
glassdave's Avatar
Neno the mind boggler
its really a bit of a risk using any polyester based fillers over epoxy. The amine that is sometimes present inhibits the curing of polys and it can come back to haunt you. I would try to avoid it.
I usually use PPG's DP epoxy primers as well as their K-36. I'm sure Dupont has something, similar the reps will know.
08 OPA High Points Champion
glassdave is offline
