Need a pair of  Mercruiser cool fuel systems >
Old 04-27-2009 | 07:43 AM
35 White Lightning's Avatar
Registered User
Default Need a pair of Mercruiser cool fuel systems
Does anyone have a pair of the Mercruiser Cool Fuel systems they want to sell my 1995 35 w 502 MPI's vaporlock so bad [email protected]
35 White Lightning is offline
Old 04-27-2009 | 03:58 PM
I have two cool fuel systems I just removed from 500efi's. New blowers upgrades required more fuel than the cool fuel could provide. They are complete with the mounting brackets, pumps, and jacketed fuel lines. Let me know if your interested.
Shock Therapy is offline
Old 04-28-2009 | 12:14 AM
Registered User
Default Cool fuel
I am interested, just wondering if the 500 efi's have the same fuel system as the 502 MPI's? What are you looking to get out of them, can you take a few pics so i can eyeball if they will fit. What year 500's
Old 04-28-2009 | 11:21 PM
Default Fuel Cooler's?
The 500 set-up uses different mounting brackets and mounting locations, fuel lines are also different lenghths and configurations.The 502 fuel coolers would work much better, and easier to adapt.I have several used cooler set-ups for the 502's, I also would probably have the correct fuel line from the cooler to the fuel rail. You should also have your ecm reflashed for the later methy one calibration with fuel cool, or you may run a little rich since the fuel cool system runs slightly higher fuel pressure than the vst system. Call me if interested. 319-240-4753 Byron
BDavis1819 is offline
Old 04-29-2009 | 11:08 AM
I have two off 1997 502 MPI complete
MACTIME is offline
Old 05-13-2009 | 08:00 AM
Registered User
Default Cool fuel
Can you email me if you still have them at [email protected]
thanks Brian also if you have a pic you can send them to me
