08 F450 Towing Question
Old 04-27-2009 | 08:33 AM
duke252's Avatar
Default 08 F450 Towing Question
Quick Question. I picked up an F450 last week. The mount/hitch on the back of the Truck is rated at 16K lbs w/ weight dist. hitch, but only 8k lbs for weight carrying/std towing. I'll be towing about 13K lbs MAX.
So my question is for guys that have a 450 and are towing above 8K lbs, which direction will be better, install a Class 5 mount and hitch and go with a standard setup, or leave the current mount on there and get a weight dist hitch. I've never used a weight dist in the past, so I'm not sure what the dis/advantages are and what are the cost differences if any?
Thanks for the help.
duke252 is offline
Old 04-27-2009 | 08:39 AM
Weight distribution would be a better choice for several reasons. Also, the hitch and owner's manual instruct not to remove the factory installed hitch which could be a liability issue later.
fountain 47 sc is offline
Old 04-27-2009 | 12:04 PM
duke252's Avatar
I'm guessing you have a WD Hitch on your F450?
duke252 is offline
Old 04-27-2009 | 12:10 PM
Thumbs up
Yes. I far prefer that towing heavy loads. I also have a B&W turnover ball for gooseneck towing, but in my opinion, the weight distributing hitch tows the best.
Old 04-27-2009 | 02:52 PM
tblrklakemo's Avatar
SeaRay Sundancer
Class 5 is going to be much easier to use and pull. 95% of people on here pull that way. WD hitches are a PITA.
tblrklakemo is offline
Old 04-27-2009 | 05:59 PM
I disagree about the PITA. Putting the WD arms on takes about 30 seconds a side.
Old 04-27-2009 | 08:21 PM
duke252's Avatar
Having not used WD hitch before, the setup seems a bit complicated. According to the owners manual Fountain 47SC is correct. Thats kind of why I asked the question, trying to figure out what the "masses" are doing.
I've always used a Class 5 in the past (F350 SRW). I've been told that the Std Mount on an F450 is a Class V, but the instruction/information sticker is faded and hard to read, so I can't confirm.
I appreciate the input, I realize I've got plenty of truck, just trying to be as safe as possible. Thanks again.
duke252 is offline
Old 04-27-2009 | 09:19 PM
bowtie's Avatar
My F450 came with the same hitch. Go for the Reese rated at 16,000 lbs.
bowtie is offline
Old 04-27-2009 | 10:42 PM
Barrydet's Avatar
Default Hitching up!
Sir:
You already have a WD receiver on your new truck. You just need the coupling equipment to make the WD work for you. Boat trailers typically have a "pole" style rather than a "a-frame" configuration at the coupler. I have had good results with a "Equalyzer" brand coupler. It is the only assembly I found that will mate with the "pole style" front end of a boat trailer. The coupler assembly attaches to the drawbar that slides into your WD receiver. The tension bars link the coupler to the trailer frame. When the tension bars are adjusted properly, you will see the entire truck squat about an inch on its suspension at the front and rear axles. You are moving that 1000+ lbs of tongue weight and distributing it over both axles of the power unit. The WD assembly will provide you with improved stability and sway control as you cruise on down the highway. Money well spent...
Barrydet is offline
Old 04-28-2009 | 06:54 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Info on WD hitches on past posts:
http://www.offshoreonly.com/forums/g...tch-balls.html
http://www.offshoreonly.com/forums/t...ing-hitch.html
If you are going to us a WD hitch, I highly recommend an Electric/Hydraulic trailer brake system.
It does work with Surge Brakes, but it wears all of the coupler mechanisms quickly.
Sydwayz is offline
