Sport Master    VS     CLE >
Sport Master VS CLE
Sport Master VS CLE
Old 03-23-2002 | 01:11 PM
Hot Boat's Avatar
Team Dysfunctional
Default Sport Master VS CLE
On a 2.5 what is the deference between a sportmaster lower unit Vrs a CLE (crescent leading edge). is one stronger internally than the other??? dose one create less drag than the other. On a twin set up can you use a sportmaster on one motor and a CLE on the other, what about cost deference???
Paul
Hot Boat is offline
Old 03-23-2002 | 02:33 PM
Default SPM vs CLE
Hi!
Check out www.screamandfly.com They have an article on CLE vs SPM.
If I am correct, the bullet at the CLE is thicker than SPM. SPM is faster as it is a newer design. It is made for 85 mph + speeds. It has heavy duty internals (bearing carrier, gears, etc). I am not shure about the internals in a CLE.
You should run identical lower units since you may experience handling problems in high speeds if different units.
The fastest lower unit is a Torque Master with Bobs Nose Cone and high performance torque tamer. A TM has heavy duty internals.
Good luck, Toffen G
Toffen is offline
Old 03-28-2002 | 01:52 PM
Firewalker
The CLE and Sportmaster both have heavy duty internals, the sportmaster is the stronger of the two. I would not run one of each.
As for which is faster, it really depends on the boat.
You can no longer buy a CLE from merc.
RT
SPEEDTOOL
Drives and Lower Units
3
07-30-2008 11:42 AM
Nauti By Nature
Fountain
17
02-15-2006 10:43 PM
hirschlegal
09-27-2005 12:41 AM
O-Limit37
02-03-2003 03:38 PM
Goodfella
02-28-2002 10:15 PM
