525 EFI Upgrade >
525 EFI Upgrade
525 EFI Upgrade
Old 04-28-2009 | 05:12 PM
Default 525 EFI Upgrade
Starting to get my ducks in order for the upgrade of my stock 525 EFI's, would like to get them up to the 625 HP mark and would like to see what ideas or combinations are out there to stay with non whipple stock EFI components. I have aquired a spair set of stock heads to get reworked and wanted to see what would be the best combination.
laszlo01 is offline
Old 04-28-2009 | 06:21 PM
Dustin, can recal your brain and a few hundred rpm's more and you'll be there, most 525's are 540-550 hp stock
pumpkin is offline
Old 04-28-2009 | 06:27 PM
Wahoo ATV's Avatar
Racer
You need to call Tyler Crockett. He has two packages for the 525 that will get you more than 625hp with stock ECM, Merc Heads, Stock exhaust and intake. He is in Michigan too.
http://www.crockettmarineengines.com/index.html
Wahoo ATV is offline
Old 04-28-2009 | 07:16 PM
why not have dustin whipple reflash the ecu's??
stainless is offline
Old 04-28-2009 | 09:40 PM
From one Laszlo to another. jo szerencset.
PARADOX is offline
Old 04-29-2009 | 01:49 PM
Koszonom szepen. Always good to meet another Hunky.
What is a whipple reflash ? is that a supercharger progam setting on a standard N/A motor ?
I just got a extra set of 525 heads to get port worked and go from there, will be next winters project since we are pulling the motors apart anyway, so might as well bump up the HP.
laszlo01 is offline
Old 04-29-2009 | 02:35 PM
pm203's Avatar
The Merc computer codes have been cracked. There are several ways now to bump the HP. I am told that they can be stretched to 700 HP without supercharging!
pm203 is offline
Old 04-29-2009 | 04:37 PM
Are you talking with no mods ? what are the details.
laszlo01 is offline
Old 04-29-2009 | 05:04 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Right, but only in Washington, North Carolina, and only good for 8 laps!
Sydwayz is offline
Old 04-29-2009 | 05:07 PM
Wink The Truth Need not Hurt!
Sorry to rain on your party guys, but there seems to be a misconception in the performance boating community that there is all kinds of hidden horsepower to be unlocked with performance marine engines with simple ECM reflashes.
The truth is Mercury racing has programmed the HP525 to its best horsepower at its rated rpm whre it will live! Unless you go into the engine and start making changes to cubic inches, cams, heads and induction system you are not going to see magic horsepower with any ECM reflash, anybody who tells you such is blowing smoke up your bung hole!
Best Regards,
Ray @ Raylar
Raylar is offline
