1995 Baja 454EFI Alarm? >
Old 04-30-2009 | 01:28 AM
Default 1995 Baja 454EFI Alarm?
Hey Guys, I know my boat is supposed to have an "alarm" that sounds when you first turn the key "on", but, somewhere or somehow its been disconnected and/or removed [not by me]. Can anyone tell me if the actual alarm itself is still available from Baja?, or someone else? and where its mounted?
I would also need to know what its wired to?, if someone has access to a wiring diagram that would be great! and I will dance at your wedding!, ha ha.
I know "something" is still hooked up, since if you turn the key quickly from the "off" to the "start" position nothing happens, but, if you turn the key from "off" to the "run" position and wait a couple of seconds [you can hear the fuel pump prime] THEN turn the key to "start" the motor fires right up.
Any input would be greatly appreciated, I have fixed or changed/replaced all the major things I needed to do, now its just a few minor issues [like this one] and I should be all set and actually able to enjoy the boat!
Thanks for any help guys, its appreciated!
Michael
n20michael is offline
Old 04-30-2009 | 11:50 AM
29KILROY's Avatar
If is under the Dash and is Black and Round.
Tan/Blu -Warning system sense wire (Audio warning)
29KILROY is offline
