Hydromotive props. >
Hydromotive props.
Hydromotive props.
Old 04-30-2009 | 01:36 PM
Default Hydromotive props.
Hi all. Does anyone have any experience with Hydromotive props on Baja? Specifically 30 Outlaw. Have stock Bravo 26p and was thinking about trying the Hydromotive 4 blade. Thoughts? I am trying to figure between 25 and 26 pitch. Any info would be appreciated. Thanks-Jason
JBOUTLAW is offline
Old 04-30-2009 | 02:56 PM
Default hi
how many inches do had kell/prop shaft??? if is more thar 4 1/2 sure the hydromotive is gonna work better.bravo one is a semi surface p[rop that like run over 4 1/2 inches.
MIAMI/BAJA is offline
Old 05-01-2009 | 10:59 AM
I don't completely understand the response. They are stock Bravo drives.
JBOUTLAW is offline
Old 05-01-2009 | 11:12 AM
The cleaver style hydromotives generally
don't work that well on Baja's
( not enough bow lift)
The X series props may work better,
they're more along the lines of the
bravo series of props.
JaayTeee is offline
Old 05-04-2009 | 12:42 PM
Dock Holiday's Avatar
Charter Member #34
You need the "X" props.
I tried a pair of 28 pitch P5X five blades and they planned off easy and mid range was good but I lost on top end a little.
They felt funny and I still got more stern lift then bow lift.
Dock Holiday is offline
Old 05-04-2009 | 01:33 PM
Thanks for the info. Looks like I should stick with the Bravo's.
JBOUTLAW is offline
