Drive shower on IMCO SC
The IMCO SC drive does not need an external drive shower. Water is circulated up the speedo passage and plumbed into the upper housing where it circulates through cooling cavities and out the top cap area. The cooling passages are designed and cast in the upper tower for increased heat transfer. A slight modification is required to the bellhousing but it is covered in the installation manual for the SC Drive. No external drive shower is needed, and the upper bolt patterns are different so current showers will not fit. Ray, your SC Drives will ship tomorrow, for once something actually happened ahead of schedule.
dloftis
06-20-2002 10:25 PM
