2001 Velocity 280 >
2001 Velocity 280
2001 Velocity 280
Old 03-24-2002 | 12:08 PM
Default 2001 Velocity 280
I just bought a 2001 Velocity 280 with 28 hours down in Florida. Has 502 MAG . The prop was off but is a 24..the guy told me Velocity says to run a 28. Any info? The boat looks almost new and was a bank repo. I really like the Velocity but it's completely new to me. Can Velocity owners or people with knowledge tell me what to expect form this boat as far as handling,power,top speed,ect?? Thanks Chris
LakeBum is offline
Old 03-24-2002 | 03:48 PM
BODYSHOT1's Avatar
Thumbs up
Congratulations!..that is sweet!!...looks like the 28 that's on the Velocity website...
Good Luck with her!
BODYSHOT1 is offline
Old 03-25-2002 | 12:10 PM
Every Velocity I've seen came with a 26" Hydromotive QIV.
JohnJan is offline
Old 03-25-2002 | 01:37 PM
With a 24 inch prop it will be uderpropped. With a 26 hydromotive 4 blade you should be 68 to 70 mph on GPS the sppedometer will likely be in the mid to high 70s.
Nice boat, good luck
Padraig is offline
Old 03-25-2002 | 01:50 PM
Revelocity's Avatar
Congrats and Welcome Chris.
My prop guess would be a 24" Hydromotive Q4 for the 502 Mag. A 26" Bravo 1 may also be a good candidate for rougher water. The best bet of course is to call the Velocity factory - they'll steer you to the right prop. Also ask about trim/tab settings. Padraig should be able to help with 280 handling tips as well.
The 280 is probably the best balanced hull (well maybe the VR1 is now) until you reach the 390. Good luck!
Revelocity is offline
Old 03-25-2002 | 01:52 PM
Revelocity's Avatar
I stand corrected by Padraig as we posted at the same time!
Old 03-25-2002 | 06:46 PM
mmo jo
I have a 24 hydro off of my 260 that is slightly labed for sale.$300.
Old 03-25-2002 | 09:20 PM
Linster's Avatar
Off the Radar
Stay with the 26 Bravo1. Velocity sells all boats with Hydromotive but they are hard to come off plane and the mid range sucks. The Hydromoyive is 1 mile per hour better on top end than the Bravo with both props being stock. The Bravo will bite coming out of the hole and will be 4-5 mph better in mid range than the Hydromotive. I had my bravo labbed and it was better on top end than the Hydromotive. Great looking boat!!
Linster is offline
Old 03-26-2002 | 02:50 PM
Linster, what boat/engine are you running that prop combo on. I've had a couple of 26" Hydro QIV's blueprinted with varied results on my 26' T'bred w/509. I'd be interested in trying a Bravo since 90% of my use is at cruise speeds. Thanks in advance,
John
JohnJan is offline
Old 03-26-2002 | 05:33 PM
Linster, could you post the differences in speed at various RPMs. I am happy with my labbed hydromotive but have not tested it against a bravo. Thanks
Padraig is offline
