Blown Head Gasket?? >
Blown Head Gasket??
Blown Head Gasket??
Old 05-05-2009 | 06:16 PM
Registered User
Default Blown Head Gasket??
I think I know the answer to this, but I thought I'd throw it out there to see if I may be missing something....
525SC...Last run of last year, developed a miss...figured a fouled plug...put it away for the winter. Spring time, fresh plugs fire it up...miss still there, maybe a bit of stale fuel. Fresh fuel, fire it up, miss still there. All plug wires check out good. Ok...Soooo, I do a compression check.
#1-125, #3-125, #5-125, #7-125
#2-125, #4-125, #6-000, #8-60
It appears that I have at least a blown head gasket between 6 & 8. Unless I'm missing something, & it could be something else, it looks like my boating season just got a bit shorter.
Any input on this will be greatly appreciated.
I plan on pulling the top end down on Friday, hopefully it will be nothing more than a head gasket.
rangerrick63 is offline
Old 05-05-2009 | 06:36 PM
If the plugs looked fine ,kind of. then i say head gasket.
If not ,,i say reversion ,,water . How does the oil look.
#6+8 are most likely the first ones !
DareDevil is offline
Old 05-05-2009 | 06:51 PM
Registered User
There was no water in the oil...
I really am thinking positive....Head Gasket....Head Gasket...
Thanks...
Old 05-05-2009 | 08:00 PM
GPM
GPM is offline
Old 05-05-2009 | 09:36 PM
Registered User
Reversion will cause low or no compression?
I had always thought it to be water intrusion thru the valves, & down past the rings into the oil. I'm not seeing how this would cause a compression problem.
Perhaps I've misunderstood the whole reversion problem. I've also heard that reversion was checked thru a "leak-down" test, not a compression test.
Old 05-05-2009 | 09:53 PM
It would cause the valves to pit and corrode and not seal.
0 is really bad. Even with a blown head gasket, I would expect to see some compression.
No reason to try and guess. Might as well just pull the head.
Griff is offline
Old 05-05-2009 | 10:07 PM
Reversion has a hard time getting in supercharged motors.
We have seen somthing like this before we have two customers blocks in shop now head gasket went first then burnt block between cyl, on the supercharged motor customer did not notice boost went down because it was making up for leak in gasket but the flame travel transfered between cyl and burnt block!
I hope this is not the case but supercharger makes up for some loss of cyl!!!
Good luck keep us posted.
Thumper
thumper038 is offline
Old 05-05-2009 | 10:22 PM
johnnyboatman's Avatar
do a leak down, zero is bad, just went thru same thing leak down showed 30percent had water in cyl was reversion i think. pressured block heads and intake held 15#30 mins so if it was a head gasket it would had leaked then.
johnnyboatman is offline
Old 05-06-2009 | 06:37 AM
check the valves as well and if they have not been changed in a while time for new valve springs as well
ezstriper is offline
Old 05-06-2009 | 07:28 AM
PatriYacht's Avatar
With those compression numbers, I'd just pull the intake and heads and take a look. Might be a good time to do a valve job while it's apart.
PatriYacht is offline
