Tell me if this will work
Old 05-09-2009 | 01:43 AM
Velocity Vector's Avatar
Crazy Energy
Default Tell me if this will work
I got my toung weight right and this is what I ended up with in the rear. I haven't cut anything yet. The last pic is what I'm thinking of doing. Just to get an idea how it looks. I don't have enough length to have a drive guard and I don't want to add to it and really don't want to cut it off either just remove the 2 center crossmembers and leave the length stinking out on the sides. Do any of you see a problem with doing it this way? It is basicly the same as having a short drive guard isn't it?
Attached Thumbnails Tell me if this will work-dsc_0007.jpg   Tell me if this will work-dsc_0010.jpg   Tell me if this will work-dsc_0014.jpg
Velocity Vector is offline
Old 05-09-2009 | 10:28 AM
I'm afraid if you're pulling the boat on the trailer or powering on in the wind your lower units may hit those ends where the taillights are. It may be ok the way it is if you exclusively float off and on with the drives all the way up.
pookie is offline
Old 05-09-2009 | 04:28 PM
what size velocity is that? if im right thats the 33 deep impact trailer that was bought from hideaway. you might be better off selling that trailer to lucky strike. he has a 33 contender with trips and is looking for an aluminum myco. if you start cutting on that trailer i think you'll wish you hadnt. the aluminum trailers are very sensitive to being exact. the welds tend to break if the weight is not distributed correctly
gofastkyle is offline
Old 05-09-2009 | 05:23 PM
Crazy Energy
VELOCITY 32' and it was for a 33 impact. We have the bunks repositioned to fit the Velocity so it is not for sale, just looking for some ideas for the back of the trailer. The boat only weighes 7K and it is a 15K trailer.
Old 05-09-2009 | 05:52 PM
if you want to leave the main frame pieces long, cut out the cross members that would be in the way, then reweld the pieces that hold the tail lights in on the outside.
Old 05-09-2009 | 07:51 PM
Crazy Energy
Like this
Old 05-09-2009 | 08:07 PM
Yep. That would give you a bit more prop clearence. Plus if you keep your tie down point towards the back it will help to keep your boat from sliding forward in a emergency braking situation.
Old 05-09-2009 | 08:13 PM
Box it in and and install the marker light. Run the wires through the old marker light hole.
Old 05-09-2009 | 10:44 PM
I would do it like this ,with a drive guard !!!
Attached Thumbnails Tell me if this will work-100_0266.jpg   Tell me if this will work-rays-3.jpg
DareDevil is offline
Old 05-10-2009 | 01:40 AM
Crazy Energy
I think your right DD, I like it .. I'm gona try it with the guard. It will also make the trailer and boat look more perporshinal with each other since I have it so far foward on the trailer. I won't have to add much if I don't widen it like this one I found. Those engines on that mayco you got there are staggerd and drives are closer together looks like. How much room do you need between trailer and props to be safe?
