block mounted starter? >
Old 05-10-2009 | 08:21 AM
TomFTM's Avatar
Default block mounted starter?
What marine starter are you guys using on a bbc block mounted bravo set-up with a larger oil pan and straight bolt pattern with 168 flywheel. Block is a merlin pro block with eikert 10 qt cast alum pan.
Thanks , Tom
TomFTM is offline
Old 05-10-2009 | 08:39 AM
hoozeyurdaddy's Avatar
look at some of the aftermarket high torque starters like hardin marine 620-S1934MC, there worth the money and will crank over anything.
larry
hoozeyurdaddy is offline
Old 05-10-2009 | 05:49 PM
TomFTM's Avatar
thanks, nobody else has suggestions
TomFTM is offline
