500 hp
Old 05-10-2009 | 05:53 PM
Default 500 hp
Well its been a long winter but the shop called Friday and was ready to to dyno my motor. I had this thing completely gone over cleaned and magna. The motor is a 500 hp carbed
I ended up going with 741 cam and Brodix BB2+ heads with a blower shop 250 blower. when i went down to the shop my camera battery was dead so i will put some pictures of the motor this week. I did take a picture of my dyno sheet so i will post that.
Let me know what you guys think and i could use some advice on a prop size.
The boat is 25 outlaw 1998. Thanks to everyone that helped out with advice.
ubet28 is offline
Old 05-10-2009 | 09:00 PM
Great power. You will need a stout lower unit to handle that. I am no expert, but the air fuel ratio looks a little lean, especially at the top. May want to inquire further on that.
Sledge Hammer is offline
Old 05-10-2009 | 09:24 PM
You should be spinning that combo to at least 5500rpms. Did you go any higher on the rpms????
Griff is offline
Old 05-10-2009 | 09:31 PM
Thunderstruck's Avatar
Do you have the printout that shows the atmospheric data and the correction factor used to correct the uncorrected torque and hp to the corrected values? That info would be helpful.
Long time cult member.
Thunderstruck is offline
Old 05-10-2009 | 10:25 PM
No we didnt go any higher griff i was planning on 5200.
I will see if i can get that data thundersuck.
ubet28 is offline
Old 05-11-2009 | 10:43 AM
Way lean.
kennyo is offline
Old 05-11-2009 | 11:21 AM
Originally Posted by kennyo
Way lean.
Ditto.
Although Al Gore and his friends might not think so
JaayTeee is offline
Old 05-11-2009 | 03:14 PM
Way lean.
So what should it be. The guy at the shop is saying its fine.
ubet28 is offline
Old 05-11-2009 | 08:27 PM
12.0 to 12.5 a/f
formula 382 sr-1 is offline
Old 05-11-2009 | 09:45 PM
I just found out that the shop did not use my index regulator when they had it on the dyno would this have caused the problem.
I have no clue and this is why i paid these guys to set it up. So please i am open to any and all advice. Thanks
ubet28 is offline
