1996 bravo y-pipe flappers >
Old 05-11-2009 | 01:03 PM
Default 1996 bravo y-pipe flappers
I need to replace the shutters in the y-pipe for the thru prop exhaust. I'd be damned if i can even find the y-pipe on the parts look up on the BAM website. Anyone help me out with either a p/n or help on where to find it on the parts diagrams. 1996 502mpi. w/ bravo.
cloudmaster_321 is offline
Old 05-11-2009 | 01:21 PM
This should work.
http://www.mercruiserparts.com/Show_...EXHAUST+SYSTEM
JaayTeee is offline
Old 05-11-2009 | 01:48 PM
807166A-1
I believe is the part #
boatnt is offline
Old 05-11-2009 | 02:53 PM
yup, thanks guys........
Old 05-19-2009 | 10:26 PM
Well, i got these, ended up not being correct. They are bigger than my y-pipe opening, plus, the holes are round, and dont use the little square holders on the end. Back to the drawing board.
Old 05-19-2009 | 10:32 PM
I can not find the " exhaust system" as you pulled up anywhere.
Old 05-20-2009 | 12:33 AM
Look under your year of engine in the parts area, Then look it up under the exhaust system area, but this should be your link.http://www.mercruiserparts.com/Show_...EXHAUST+SYSTEM
Boat Tech is offline
Old 05-20-2009 | 07:35 AM
I don't find anything labeled as exhaust system for my motor. Also, the shutters in that link are not the ones i have. I pulled apart the starboard side last night. Wasn't anything there at at, but there were to little holes front and back of the y-pipe. There is definately no spot for the rectangular rubber plugs. Looks like it's made for a round shaft? This has the impco power plus manifolds, and diverters. The y-pipe wouldn't be theirs as well would it?
Old 05-20-2009 | 03:33 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
That picture look like the old style flappers. When I replaced mine (same as pic) the new didn't use rubber plugs, but a holder that snapped into the holes in the y-pipe.
US1 Fountain is offline
Old 05-20-2009 | 04:37 PM
Yeah, the part that i got looks exaclty the same as the picture. But the holes in my y-pipe are small, like 1/8 inch holes. There wouldn't be any use for the rectangular rubber plugs. Also, the shaft that these shutters are on is also rectangular, not round like the holes in my y-pipe.
