Bravo red-dot gimbal bearings 862540A3
Offshoreonly Advertiser
We have a bunch that came out of damaged transom assemblies, they are new never used. I just put them on Ebay for $34.95 each.
http://cgi.ebay.com/ebaymotors/ws/eB...CA:MOTORS:1123
Doing some spring cleaning around here, more stuff soon!!
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
Ebay busted me, I had a link to our web site in the listing.
New auction is:
New auction is:
Marc
www.go-fast.com
www.bammarine.com
Marc
www.go-fast.com
www.bammarine.com
Yes, complete with ring.
Do you want just the shift cable bellows? PN is 74639A2 comes with the clamps
Or the entire repair kit? Exhaust, u joint & shift bellows along with water hose & gimbal bearing PN 803100T1
If you want to order the bearing directly use our site and order with the standard PN 862540A3 - just put a note on the order to send the Ebay bearing and we will adjust the price.
http://www.mercruiserparts.com/partsByNumber.asp
Marc
www.go-fast.com
www.bammarine.com
Marc
www.go-fast.com
www.bammarine.com
Correct me if I am wrong. Does not the Merc Bravo service manual state that the gimbal bearing would be damaged if removed, so new replacement is necessary?
The service kit number given to Elite is for early (1998) Bravo one drives too?
Rotax,
Yes, the bearing MAY be damaged if removed incorrectly. The only way to pull the bearing is to grab it by the inside race which is not a great idea as the force is transmitted through the balls to the outer race. This can imprint the races. However from a practical standpoint this is only a possible issue if using a slide hammer, and even then you really have to whale on it to cause a problem. It is not an issue if you use a threaded rod & plate to pull nice and even.
Same thing to install, do not beat on the inner race, use a driver that pushes on the outer race.
Yes - same kit for all the Bravo's
Boomer - I'm not sure if we have any left, I'll take a look in the AM.
Marc
www.go-fast.com
www.bammarine.com
Marc
www.go-fast.com
www.bammarine.com
