Draining antifreeze from 496 mag ho >
Old 05-14-2009 | 10:01 AM
Thumbs up Draining antifreeze from 496 mag ho
I am attempting to change the antifreeze in my 2003 496 mag ho engines. I can't find any plugs in the block. I have drained about 75% of the antifreeze by removing one of the lower hoses, but can't figure out how to drain the bolck. Any suggestions would be appreciated.
gmbfootin is offline
Old 05-15-2009 | 01:27 PM
Wink
Question, why are you draining the antifreeze??
Best Regards,
Ray @ Raylar
Raylar is offline
Old 05-15-2009 | 03:53 PM
They're 18mm hex plugs that have an allen pattern also in the head. They're obvioulsy black and hard to see.
The starboard one is almost but not quite behind the oil dipstick tube and blends in very well....
The port one is slightly above where the old generation KoolFuel would rest. They're not easy to get to. I made another post about using the Snap-On Socket, FSUM18A as an easier means of getting them out and back in..
SDFever is offline
Old 05-15-2009 | 05:28 PM
Default Thanks
Thanks for the help. The reason I am changing the antifreeze is Mercruiser recommends it be done every 5 years. I spoke to one of Mercruiser reps at a boat show & asked him why, & he told me it looses it lubrication properties & also forms a gummy substance that can block the passageways. For the price of 5 gallons of antifreeze, I figured it was cheap insurance. Thanks, again, SDFever.
Old 12-08-2013 | 07:12 PM
Raylar, do you think changing antifreeze is unnecessary??? Ed
38fountained is offline
Old 12-09-2013 | 07:46 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It is 100% necessary. It will silt up after 5-7 seasons; and not flow or cool as well. If your antifreeze bright pink, it's probably still fine. But if it starts to turn silver/metallic--it's time to change it.
Sydwayz is offline
