Water in the trim fluid
Yes they can get water in and not leak. I had a trim seal fail and sucked water in and never leaked oil near I could tell. I knew if was the ram seal because plating failed and shaft was rough. Rebuilt the ram(had shaft replated) , flushed the system and water free for past 3 years.
I bought my boat in 2001 (35 Nordic with twins).
Around 2002 the port trim pump had milky water contaminated
oil one day.
All I did was change the oil.
Problem has never come back in 7 years and 400 hours?
Pesky Varmint
oil one day.
Pesky Varmint
A couple years ago I had the same problem. Ended up finding that water was dripping directly onto the trim pump cap when it drained off the hatch. Since I had a top vented cap the water was getting sucked in. Changed to a side vent cap and the problem went away. It sucked to eliminate the water from the system, but after that it was a $5 fix. . .
