99 4x4 Lifted Single Cab 450hp 408ci Stroker FS/TRADE
450hp Dodge Dakota 4x4 Custom Limited Factory Build
Click the YOUTUBE logo to view a bunch of videos!
Images
Click image thumbnail to view full size
Description
A lot of love, time and money has gone into my truck but with the price of school loans forthcoming, I am forced to pass it on. The truck is in mint condition inside out and has been my garage kept pride and joy for the past 6 years.
I recently had a brand new 450 horsepower 408ci (10.3 comp) long block professionally installed from KRC performance. It came with a Mopar M1 4bbl intake manifold, ported eddelbrock aluminum heads, scorpion 1.6 rockers and a 242/248 108 cam. The truck also has a fresh Dr Evil "Pure Evil" 46RE w/ 2800stall behind it. The trucks exhaust consists of stainless steel headers, a catless single in dual out flowmaster 40 and 4" x 22" stainless steel tips.
Also recently upgraded is the braking system with drilled/slotted rotors and new calipers. Along with the stopping power upgrades, the entire front/rear suspension, steering, wheel hubs have all been replaced recently as well.
The truck sits on 33x12.15s Nitto Terra Grappler All Terrains with 15x10 Weld Racing aluminum wheels. The stock headlights have been replaced with diamond clear cut lights and corners. Also enhancing the appearance of the truck is a 5 piece stainless steel billet set.
The truck is very street able and can be driven daily. It gets about 11mpg in the city and 16 mpg on the highway. The truck goes 0-60 in 5 seconds and has run the 1/4 mile in the 14's. The motor is built for nitrous but has never been sprayed. This truck is one of a kind and you will not see another one like it. A fast, lifted regular cab 4x4 with great styling is very hard to come by.
The motor is a solid foundation and can further be improved to net even more horespower! Future plans for the truck included a larger throttle body, longtube headers, larger true dual exhaust, underdrive dampner, larger injectors, a new more aggressive tune and 150 shot of nitrous. With those modification this truck is capable of producing 800hp!
This is not your average run of the mill Dakota nor is it a lightly self modified truck. It is a fully professionally built race truck inside and out. If you are loan dependent and looking to pay blue book value or even close don’t waste either of our times as low ball offers will be ignored. Just the motor alone was 10k!
Make: Dodge
Model: Dakota Regular Cab Short Bed
Miles: 83,000
Year: 1999
Engine: KRC Performance 450hp 6.7L 408 Magnum Stroker (nitrous ready)
Transmission: Dr. Evil 4spd Auto 46rh w 2800 stall
Factory Options: Power Everything, Convenience Package, Tow Package
Performance Upgrades @ 81k miles - $14,000+ invested
KRC 450hp 408 6.7L Street Long Block Stroker @ 81k miles
ROSS Forged pistons (10.3 compression)
Seal Power Rings
Eagle I-BEAM Rods
Eagle Cast Crank
Comp Cams 242/248/108 Cam
Eddelbrock Ported/Polished Aluminum Heads
Mopar Magnum Valve Covers
Comp Cam Double Roller Timing Chain
Cometics Head Gaskets
Complete Engine Gasket Kit
ARP Head Studs
Scorpion 1.6 Roller Rockers
SHM Damper
CHM Nascar Pushrods
Melling HV Oil Pump
Clevite Main / Rod Bearings
408 Oil Pan
Mopar M1 Intake Manifold
52mm F&B Port/Polish Throttle Body
Electric Fan Conversion
MSD Ignition Upgrade
Stainless Steel Headers
Flowmaster Dual Exhaust w' 4" Tips
SCT Handheld Tuner
Dr. Evil, Pure Evil 46rh Transmission w/ 2800 stall
Drive Line Upgrades @ 76k miles - $1,600+ invested
Upper Ball Joints
Lower Ball Joints
Inner/Outer tie rods
Pitman arm
Control arm
Calipers and Pads
Drilled/Slotted Rotors
New Front/Rear shocks
Two Wheel Hubs
Steering Gear Box
Appearance Upgrades - $4,000+ invested
Exterior
6 inch Suspension Lift
15" Stainless Steel Wheels
33x12.50x15 Nitto Terra Grapplers
Stainless Steel Billet Grille
Stainless Steel Westin running bars
Diamond Cut headlight and turn signals
Interior
Triple Pillar Pod and Gauges
White Instrament Gauges Air/Fuel, Trans Temp, Vacuum
Sound Upgrades
Sony Xplod Mp3/CD Player
Pioneer 6.5" Front Speakers
Pioneer 5.25" Rear Speakers
8" Kicker Competition Sub
MTX 664 4 channel amp
Pricing
Kelly Blue Book Value(STOCK) - $7,900
Total Recent Upgrades Value - $19,600+
Total Vehicle Value - $27,500+
Total Vehicle asking Price - $13,000 FIRM!
Preferred Trades
2003+ Infiniti G35 Coupe with less than 80k miles
2007+ Dodge Charger v6 with less than 50k miles
2006+ Honda Civic Coupe with less than 20k miles
2006+ Jeep Grand Cherokee with less than 25k miles
Will also trade for small mazda pickup, chevy colorado, +/- cash depending on miles and condition.
Contact Info
For the fastest response email me at [email protected]. This truck is located in ORLANDO FL and shipping can be arranged if need be. I am also willing to deliver the vehicle up to 500miles with an added fee. Test drives and vehicle showing for serious buyers by appointment only.
No offence at all here but not really a tow rig for most of the boats on this forum that are on a trailer. I sometimes use a 1/2 chevy with 1 ton spring and its not really the truck for it. Thats why i used a 1 ton diesel or so. But good luck on the sale the smaller boats with out boards wouldnt have a problem id say
-Mike
-Mike
-Mike
-Mike
No offense taken. it towed a 4 wheel trailer loaded down with stuff when i moved last time and the back end didnt even sag at all.
Did i mention i have a clear title in hand and can provide a carfax.
