Chevy 350 hp? >
Chevy 350 hp?
Chevy 350 hp?
Old 05-19-2009 | 10:14 AM
Default Chevy 350 hp?
I'v got a 350 bored 30 over. I'm curious what kind of power I should expect out of this. Here is what I'm running.
Speed Pro .10 domed piston
Std cast heads ported and polished
Comp camps x-treme marine 262 cam
Roller rockers
Stealth Intake
750 Edelbrock Carb
I'm hoping this combo gets in the the 350-375 range, any opinions on this?
Thanks-
endeavour32 is offline
Old 05-19-2009 | 11:17 AM
Around 325-350 should be about right.
niceguy is offline
Old 05-19-2009 | 11:30 AM
Even though I've had some work done to my old heads would I be better off with a set of vortec heads?
Old 05-19-2009 | 11:52 AM
Roller rockers
Stealth Intake
750 Edelbrock Carb
Thanks-
What exhaust are you running?
jeffswav is offline
Old 05-19-2009 | 12:05 PM
The vortec heads will not work with the .100 dome piston.
RHM253 is offline
Old 05-19-2009 | 05:44 PM
wayne272's Avatar
I am running .040 over 350, flat-top pistons,block was decked (maybe.010)crane h-272 cam,engine quest vortecs,air-gap intake,650 DP,GLM cast manifolds/4" risers. Engines dynoed365hp/400 ft.lbs.
wayne272 is offline
Old 05-19-2009 | 11:40 PM
Right now I will be running the stock manifolds. I know I'm going to need aftermarket manifolds. What do you all suggest that are the best value?
Old 05-20-2009 | 08:49 AM
Stainless Marine
GoFastSonic is offline
Old 05-20-2009 | 10:23 AM
CB-BLR's Avatar
Chris
Revolution Marine for the exhaust.
http://revolutionmarine.com/shopsite...bcexhaust.html
Chris
CB-BLR is offline
Old 05-20-2009 | 10:26 AM
Registered User
I'm currently building a similar setup for my Baja204 I'm using aluminum EMI Thunder manifolds/stainless risers.
My Motor:
355 four bolt main truck block/forged crank
Manley flattop pistons 10:1
Manley 6in H beam rods
Brodix Track 1 aluminum heads 2.08/1.60
Comp Cams Extreme Marine 270 hyd roller/beehive springs
Comp Cams Magnum roller rockers
Edlebrock Performer RPM intake
750 AFB
EMI Thunder exhaust straight out the back!
Marco
Holeinthewater is offline
