496 and 500hp exhaust >
Old 05-19-2009 | 02:26 PM
Default 496 and 500hp exhaust
will 496 exhaust bolt to 500 hp heads or is a diffrent bolt pattern.
rssteiny is offline
Old 05-19-2009 | 03:07 PM
Just for kicks I bolted up my 496 HO CMIs to my new 525 EFI. The ports lined up perfect and so did 4 of the bolt holes. You would need to re-drill 4 holes per side and they should work. This is with headers with a flange. Of course cast manifolds do not have a flange and cannot be redrilled.
thirdchildhood is offline
Old 05-20-2009 | 01:38 AM
The 525 is different and has special heads and different exhaust bolt pattern.
Merc 496 exhaust will bolt right up to 454/502 rect port heads.
Griff is offline
