Tell me about the ASD6 bravo conversion >
Old 05-19-2009 | 02:58 PM
Default Tell me about the ASD6 bravo conversion
Just a few questions on this conversion.
1.) Price
2.) Advantages over Bravo
3.) Speed Differences
4.) Pad bottom boat with Surface Drives?
My latest project wont have drives or engines in a 33' pad bottom V. Im researching what drives to put on and have considered XR's for the most part. But Ive always loved the roostertails and reliability of a surface drive. HP will be roughly 700/side but dont have room in the bilge for transmissions. The boat was originally a bravo boat boat. Other than reliability and looks, what other advantages are there to making the conversion?
Im concerned about the pad bottom on this boat affecting the drives, is this an issue at all?
waterboy222 is offline
Old 05-20-2009 | 01:56 AM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
The pad bottom will not make a difference. The Fountains have a "Pad Bottom" and we have proven that the Arnesons work extremely well on the Fountain Powerboats, sizes ranging from the 10M, 12M, 38', 42' and 48' models the Arnesons were and are a Fountain Factory option.
We have applications with Velocity's, and other pad bottom boats as well.
Power is not a problem as you are within the warranty limits of the #7M's.
Speed: Typical 10 mph midrange and 10 mph top end over a Bravo.
List price is $23K per side.
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 05-20-2009 | 07:13 AM
t500hps's Avatar
21 and 42 footers
ASD has a test on a 382 Formula supporting the 10mph claims. The ASD/Bravo conversion puts the transmission in an extension box so that is not a problem. IMO, there are 2 factors that would send me to the ASD drive. If this boat needs drives, steering, and possibly transom assemblies. then you'd be spending close to the same money setting it up for XR's (some price offset by selling the transom assemblies) BUT...you'd end up with something that WILL eventually break with 700hp. 2nd, you don't plan on swimming around the back of the boat often....those props are out there, and sharp.
I've never had anything but Bravo's but I looked into the conversion with interest. I can't justify swapping everything over since I have all the hardware already but if it's an un-rigged boat I think it's a great option once you price all the items your missing.
t500hps is offline
Old 05-25-2009 | 12:36 AM
Rik's Avatar
Rik
This might give you more information on the kits. Note phone # is missing a digit.. oppps.
Attached Thumbnails Tell me about the ASD6 bravo conversion-arnesonbravokit2.jpg
Rik is offline
Old 05-29-2009 | 02:37 PM
Can you give an example of a speed difference on a 42 Fountain
Pokher Ace is offline
Old 05-29-2009 | 03:49 PM
Can I convert a 43 Black Thunder ove to ASD's. The Boat currently has Bmax's. Let me know prices and what all is involved
endeavor1 is offline
Old 05-29-2009 | 04:32 PM
OL40SVX's Avatar
The ASD's don't break...that might be an advantage!!!!
OL40SVX is offline
Old 05-29-2009 | 05:27 PM
Strip Poker 388's Avatar
Rob
Rik I see a bravo style prop on it? everything ive seen has the speedmaster style.
ASD "Knowing ya want be ideling home on one drive"
What sux is,I can build the power but I have to baby sit it
Strip Poker 388 is offline
Old 05-29-2009 | 06:53 PM
So if this is a Bravo conversions, then what part of the Bravo stays? What is the advantage of Bravo style props versus Speedmaster?
Anyone conver a 33' Eliminator?
stormbauer is offline
Old 05-29-2009 | 11:26 PM
c_deezy's Avatar
Thats the drive they released not too long ago. The housing is bigger to be able to use a 'bravo style' prop, so you aren't only limited to speedmaster style props. I think the going rate was around $14K for the ASD6, if I was building from scratch that's what I would go with. When you break down the cost for a drive, the hydro steering and all the other ancilliaries, the Arneson is a pretty good deal.
Bottom line - Badass :smoking:
c_deezy is offline
