Go Back  Offshoreonly.com > Owners Forum > Powerquest
2000 Silencer 280 weight >
Old 05-19-2009 | 10:04 PM
Default 2000 Silencer 280 weight
The PQ website lists a 2000 silencer 280 as weighing 7500 lbs. That can't be right. I'm looking at hoists and need to know the correct dry weight. Does anyone know for sure, or is there a number I can contact someone from PQ .I know they're out of business ----- just not sure if someone from the factory is still around. Thanks
stevewy is offline
Old 05-20-2009 | 06:39 AM
Fast Forward's Avatar
I've got a brochure at home so I'll double check but I'm going to guess around 5200lbs??
Fast Forward is offline
Old 05-20-2009 | 09:12 AM
CHAOS REIGNS's Avatar
I've got my 280 sitting on a 6200 lb hydrohoist lift -- lifts with no problems.
CHAOS REIGNS is offline
Old 05-20-2009 | 09:57 AM
4800 lbs
boatnt is offline
Old 05-20-2009 | 07:17 PM
Sorry my 97 Brochure doesn't have the 28. The 27 shows 4800 and the 29 with twins is 6500.
Old 05-20-2009 | 07:55 PM
Thanks. I'm going with a 8000 lb hoist, so it sounds like I should be fine.
stevewy is offline
Old 05-20-2009 | 08:03 PM
My 2001 28' Silencer on a steel trailer is 7240 pounds, with 100 gallons of fuel. You should be OK with the 8K lift.
MacGyver is offline
