number 7 cylinder overheated gen 5 502 >
Old 05-20-2009 | 01:44 PM
Default number 7 cylinder overheated gen 5 502
I have hade two engine failures due to a overheated number seven cylinder. I see no telltale signs of water intrusion or any reason this one cylinder is melting pistons after rebuild. It is a bone stock 1994 502 EFI. Anybody heard of this.
dead502 is offline
Old 05-20-2009 | 02:38 PM
what fails ? and what do the parts look like ?
stevesxm is offline
Old 05-20-2009 | 02:59 PM
The motor starts knocking. after teardown we find the piston is heavily scored and transferring metal to the cylinder wall.
dead502 is offline
Old 05-20-2009 | 03:12 PM
Running lean, injector, vacuum leak.
1BIGJIM is offline
Old 05-20-2009 | 03:15 PM
Injector problem on that cylinder ?
JaayTeee is offline
Old 05-20-2009 | 03:22 PM
Injectors were tested on the first failure. the top of the pistons are all the same (tanish in color). no signs of lean condition here.
dead502 is offline
Old 05-20-2009 | 03:47 PM
your right. it really sounds like that cylinder is getting really hot and seizing... the block isn't full of sand, is it ? ive seen that happen in raw water cooling cases. a vacuum leak would kill the top of the piston... i assume you checked the piston to wall clearence early on...
stevesxm is offline
Old 05-20-2009 | 04:01 PM
I am the owner not the builder. but I questioned the builder on that subject. they assure me all clearances were correct. this is the second failure of the same cylinder with different pistons. there opinion is it was water intrusion and it is my fault.(pay up) by the way I am a X auto mechanic of 20 years and now learning more than I ever wanted to know about boat motors.
dead502 is offline
Old 05-20-2009 | 04:35 PM
BY U BOY's Avatar
My guess is a vacuum leak in the exhaust manifold of intake.
BY U BOY is offline
Old 05-20-2009 | 04:55 PM
well.. you never know and i suppose they could be right but it seems to me that eveytime i have seen water intrusion there are about a million other symptoms that occur.
i have a hard time reconcilling a skirt seizure with a vacuum leak. if the top ring land is doing it then maybe but a skirt seizure is usually always over heat related...
i suppose a badly bent rod could do it... but this is all guesswork. if you could post a pic of the piston and bore, that would help.
stevesxm is offline
