Bravo Drain Plug Leaking
My lower drain/fill plug on my bravo drive is leaking. I changed the gasket, made sure the old one was out, and its still leaking. I guess the only thing left to try is to put a new plug in it and hope that fixes it. Anyone had this problem or any suggestions?
Had the same problem on a drive I R&R'ed this winter... The plug was fine, I helicoiled the carrier but didn't want to take a chance so I wound up replacing it with a new carrier.
http://www.mercruiserparts.com/showS...asp?pn=41641A8
You need to figure out a way to put 15psi air pressure to the bravo and see where the leak is for sure. If it is still the drain plug I would examine closely the thread, plug and gasket surface.
BT
the reason he asked if it had a drive res. was to tell if it was the early drive, if i remember right the 1988 model bravo did not have a res. and if the threads on the carrier that the drain plug screws into get worn and loose on the second version drive then it will leak at the plug. west marine carries a thicker gasket for the drain plugs you might try that
