another milkshake question???????
Here is the situation. new 640ci bbc, dart block heads and intake. the short block was brand new and the heads were off my other motor with no previous issues. first the pushrods I had were too short and it was keeping some of the valves open upon the initial start up. I pulled the plugs out and 1 of them has water and oil on it. could it just be reversion from the exhaust valve not closing? I did a leak down and it was at 3-5%. across all 8 cylinders and with the motor being brand new and the rings still not being seated I think that these are great #s I could understand if the plug was wet with just water but the milkshake has me concerned. the headers are cmi's and were also on my other motor with no issues. what do you guys think? intake leak? BTW I am using cometic head gaskets and the cam is on a 114 lobe centerline. Also the oil in the pan had a little water in it but it was far from milkshaked??????? help??????? I cant keep spending money for nothing lol.
I can not give you an answer as to what is causing your problems. I can say for sure that I have never heard of pushrods being soo short, as to be able to hold the valves open and cause reversion issues. Proper length push rods are essential for correct rocker arm and valve train geometry. Your problems may be reversion. What are your exact cam specs. 114* centerline , meaning I.L.C. is not really important. Maybe you mean 114* lobe seperation? Is it possible for you to seal off your cooling system and pressurize it like an automotive system? That will tell you if the engine is sealed tight. If it is, the problem most likely is reversion or a header leak.
I still dont follow your push rod issues, but in any case, you need the correct length in there. If your issue is reversion, water generally backs up into the cylinder, then squeezes past the rings and into the oil pan. From there, it makes a mess of everything. Including causing the exhaust valves to get brittle. Do a search here. You will see countelss threads on it. 114* lobe seperation is not too tight, but the duration has alot to do with it as well. For instance, my cam is a solid roller, 114* lobe seperation, 244* and 256* duration @ .050" . CMI headers on a N.A. 540 . This cam sucked water back @ idle speeds. I went to full dry tails to solve the problem.
Now I understand. I never thought of that possibility. They must have been reallllllly short. Looks like your cam is very similiar to mine. As I said, mine sucked back water from the standrad CMI tails. Be careful with it.
btw the cam I had in the other motor was about the same spec wise it just had a little less lift. I never noticed any signs of water in the cylinders? my tail pipes are only wet at the tip so maybe thats why.
man I just read this thread http://www.offshoreonly.com/forums/g...ater-leak.html I hope this isnt the problem. I doubt it is because I seem to have more of a problem with the water getting into the combustion chamber and less in the oil pan. there is some reaching the oil pan but I dont think its much? besides I have the dart 360 heads and I believe that they are different than the pro 1's?
