water leaking in at exhaust >
Old 05-25-2009 | 09:05 PM
rjr
Default water leaking in at exhaust
A little water is probably to be expected but I am at the point where the bilge pumps have to work if I am dragging ass. No problem on plane but at the ramp, not on plane, etc. water is coming in around one of the straight thru exhaust pipes. I have not started taking things apart but i am wondering what is used to seal that gap.
rjr is offline
Old 05-25-2009 | 09:58 PM
They make a Stainless ring with a rubber gasket that slips over the pipe and is mounted from the outside with the ring !!!
DareDevil is offline
Old 05-25-2009 | 10:09 PM
el indio's Avatar
AND WHO IS THEY. THE REAL DEAL IS CONVEYER BELT RUBBER MATERIAL WITH ALUMN. OR STAINLESS BEAUTY RING. MM.
el indio is offline
Old 05-25-2009 | 10:26 PM
I think DANA has them in the programm and others aswell.
But thanks. Beauty ring was the name i was looking for .HEHE
Old 05-25-2009 | 10:43 PM
Don't wait too long on that...I've found new transoms can be very expensive once they start getting wet.
Ryan8886 is offline
Old 05-26-2009 | 08:02 AM
rjr
Hopefully Formula did the cutout right and backed the core away from the cutout and filled with epoxy. I'll find out soon
rjr is offline
Old 05-26-2009 | 05:55 PM
Before you install the beauty ring, and gasket, put a fresh coat of fiberglass resin on the wood (the inside of the cutout). This will help protect the wood in the future. And be sure to seal the screws the hold the beauty ring on. Water intrusion is the enemy.
Darrell.
DMOORE is offline
Old 06-01-2009 | 10:54 PM
rjr
Bad news. A previous owner replaced the exhaust tips and did a poor job of sealing the original bolt holes. Big mess!!
rjr is offline
Old 06-02-2009 | 07:41 AM
seafordguy's Avatar
Oohhhuuuhhh.... Hope it isn't as bad as it COULD be??
seafordguy is offline
Old 06-02-2009 | 08:33 AM
northernoffshore's Avatar
Check out silicone rubber sheets. Stretches around the pipe last forever. comes in white and a couple different colors.
northernoffshore is offline
