Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Bravo Lower Paint remover >
Old 05-26-2009 | 11:34 AM
LV's Avatar
LV
Default Bravo Lower Paint remover
Some of my paint is comming off of my Lower half, so i was thinking about removing it and leaving it the satin aluminum or painting it silver, what kind of stripper would be good for this, not messing up the aluminum.
LV is offline
Old 06-16-2009 | 07:55 AM
i used aircraft coating remover and a wire brush on a grinder. if you want to completely dissasemble sandblasting works well too
Yoda_Man is offline
Old 06-16-2009 | 08:18 PM
carter38's Avatar
I just did my lowers silver on the 88 bullet. I will try to get you some pics tomorrow.
carter38 is offline
Old 06-17-2009 | 01:39 PM
They did look good when i saw them.
31cigg is offline
Old 06-17-2009 | 03:50 PM
I used a flap wheel on my right angle grinder and a da dander with 100 grit. Worked well and very good finish. I then sprayed it with the Merc gray primer. I think it is zinc primer or something? I then shot it with black engine paint.
baja_brian is offline
Old 06-17-2009 | 06:00 PM
LV's Avatar
LV
how did you end up doing it ?
LV is offline
Old 06-17-2009 | 07:50 PM
hoghead's Avatar
We just did Jim Diesel's drives on his 31 Sonic (scroll down the page about half way) http://www.offshoreonly.com/forums/s...ow-here-6.html
We sanded the old Merc stuff off with a palm sander and hand sanded areads that it could not get into. I think it was with 400 grit. Sandblasting is a great option only if you completely disassemble the drive...as said earlier. It will get into the drive. Had to use filler for the nose cones and blend that as well. Went with the zinc chromate primer and then several coats of the merc phantom black.
hoghead is offline
Old 06-18-2009 | 09:36 PM
carter38's Avatar
Mine were pretty ate up so I had to strip them bare and start over. I still haven't made it to my computer yet. I'll get the pics up soon.
carter38 is offline
Old 06-18-2009 | 10:44 PM
how did u strip them?
31cigg is offline
Old 06-18-2009 | 10:49 PM
carter38's Avatar
Had your shop boy do it.
carter38 is offline
