Help..wiring diagram for Alpha 1 Gen 2 >
Old 05-27-2009 | 06:21 AM
Default Help..wiring diagram for Alpha 1 Gen 2
Hi
I was recently stranded while fishing in my 1993 crestliner with Apha1 Gen 2 4.3 l LX 4bbl carb with electric fuel pump. I ended up jumpering the fuel pump positive lead to the electric choke lead to get 12 volts to the pump. Does anyone have a wiring diagram for the electric fuel pump circuit?
Jim
AlpineII is offline
Old 05-27-2009 | 03:25 PM
Originally Posted by AlpineII
Hi
Jim
Hi try this fourm they have merc service manuals to down load that will help you with what you need. Go to the merc i/o area then look for the adults only area and you will find it in there. Good luck. http://forums.iboats.com/
Boat Tech is offline
