SmartCraft Trim Limit Switch >
Old 05-27-2009 | 10:33 AM
DesertRage's Avatar
Default SmartCraft Trim Limit Switch
How does the SmartCraft Transom Assembly Trim Limit Switch work? Mine has a three wire plug coming from the limit switch (contacts labeled A, B, & C). As far as I can tell there is not much of a circuit resistance change between the contacts and all three have continuity while rotating the switch. My previous 96’ boats transom only had two wires coming from the limit switch and it was an open or closed circuit. I am aware of the Starboard side trim sender, not talking about that…
Thanks!
DesertRage is offline
Old 05-27-2009 | 12:55 PM
Thanks!
The sender you're talking about is digital. Hot, Ground, & Data. Is it throwing a code? Is there an issue or just wanted to know?
I can't use it on my drive but the ECM "wants" to see it so i leave it tucked away and turned to 180 degrees out from center so the correct voltage stays in place and not to trip the check engine notice etc..
SDFever is offline
Old 05-27-2009 | 01:10 PM
DesertRage's Avatar
Well, it was working fine, but then I "Fixed the boat" . Actually, I replaced the 496 and associated wiring with a 555ci carb engine. Which brings me to the problem. I would like to hook the limit switch back up and that is when I noticed the three wires instead of the expected two. Is there a way to use the switch with a converter or would it be best to replace the digital switch with the earlier style.
Thanks for the reply.
Jon
Old 05-27-2009 | 01:14 PM
Jon
Naw I'd just buy an older 2 wire analog sender if you really want to have a limit sender installed. The 3 wire won't work for you without the computer and harness to plug it into.
SDFever is offline
DesertRage's Avatar
Out of curiosity, why are you unable to use the switch on your drive? Did you bypass the switch and run without a trim limit (no trailer switch needed)?
Old 05-27-2009 | 01:19 PM
The factory X Dimension on my boat causes the limit swith to stop the trim when it's almost down all the way. Don't need trailer trim.
Those things fail all the time in the water and they're really only to help make it idiot proof. You know to trim by feeling, ride, and sound/vibration.
SDFever is offline
Old 05-27-2009 | 01:39 PM
DesertRage's Avatar
Thanks for the info SD! It sound like it would be best to just bypass it and pay attention to the mechanical indicator when idleing in the shallows.
Old 08-13-2015 | 10:37 AM
Rage's Avatar
Default Digital Smartcraft Trim Limit Switch
My trim up quit working. I have the three wire 'digital' trim limit sensor. How do you test / determine if switch is good or bad? Any other areas of that system/circuit that is more likely to cause loss of up trim than others? I switched the trim up relay with the fuel pump relay and still did not work. I am getting no fault codes from ECU.
Rage is offline
Old 08-13-2015 | 04:50 PM
BUP
Asking you have mechanical shift or DTS ?
a bit of info beforehand.
There is a transom harness that connects to a bunch of sensors in the transom assembly. ( Transom harness to engine harness connector). - So Asking if you connected both the trim limit connectors B and F at the sametime as this will cause a failure in the trim circuit meaning possible no trim ?
Also will need to more which wire harness and pin connections you have.
lets see there is
10 pin
14 pin
DTS 1st model yellow CAN cable
DTS - 14 pin / 10 pin
DTS - 14 pin
or even better yet the harness part number would be great to make things easier for me to tall what exactly you have
BUP is offline
Old 08-13-2015 | 05:26 PM
Haven't been able to get mine working. Installed HP transom with digital sender. Bought the digital to analog converter kit (884359T1 converter 884359T1). The limit does not work, tried all kinds of adjustments, but no luck. The gauge has started to work but works backwards. When down shows full up in the red, as I trim up it starts coming down
AllDodge is offline
