crank pulley bolts with wire >
Old 05-27-2009 | 01:23 PM
Default crank pulley bolts with wire
do i need the wire with lead that crossed between the crank pulley bolts and also ther was one on the intake bolts as well.
rssteiny is offline
Old 05-27-2009 | 01:28 PM
txriverrat2001's Avatar
Or loctite - it's the same safety wire you get from an aircraft supply house......
txriverrat2001 is offline
No You dont need them they are to identify Mercury Racing sealed engines to be used in racing classes. The lead had a stamp on it to be checked.
Thumper
thumper038 is offline
