Why havent they marinized any dual overhead cam motors??? >
Old 05-29-2009 | 07:52 AM
Default Why havent they marinized any dual overhead cam motors???
Does anybody know??? And what is the highest power DOHC engine you can buy???
302Sport is offline
Old 05-29-2009 | 11:13 AM
http://www.youtube.com/watch?v=eQwvSbQFA9U
I heard someone marinized this engine.
Dueclaws is offline
Old 05-29-2009 | 11:51 AM
MasterCraft and Cadillac had a very brief venture where they used the Northstar motor in their ski boats. It was a pricy upgrade, and other than bragging rights it did little else. Only a handful were produced and the project was scrapped shortly thereafter.
Toyota also used their Lexus V8 in their ski boat line called Epic. Also a short lived venture.
I think the low end torque of the pushrod V8s proved to be better for boat applications than the higher revving DOHC motors. Plus they are a lot cheaper.
BowenCT is offline
Old 05-29-2009 | 11:54 AM
glassdave's Avatar
Neno the mind boggler
Volvo use to have that 4 cyl cammer that had like 170hp and spun to 5600 or something like that. It was only out for a few years though. Odd little motor . . .
08 OPA High Points Champion
glassdave is offline
Old 05-29-2009 | 12:06 PM
i saw some 903ci DOHC monster motor that made like 1200hp on pump gas for a boat, but nobody has made something in the middle like say 500hp????
302Sport is offline
Old 05-29-2009 | 12:23 PM
JIMKID Motorsports's Avatar
Tim gross did the one in the video
JIMKID Motorsports is offline
Old 05-29-2009 | 01:23 PM
Brad Zastrow's Avatar
Boats like torque. Most OHC engines do not have good low end torque because to the multi valves.
Brad Zastrow is offline
Old 05-29-2009 | 01:37 PM
Id take an LSx motor anyday over a ohc.
less complex,easier to mod and gobs of power.
HTRDLNCN is offline
Old 05-29-2009 | 01:56 PM
GLH's Avatar
GLH
Amen.
GLH is offline
Old 05-29-2009 | 02:28 PM
I think the fact your all over looking is that DOHC engines are for the most part small cubic inch engines.
A boat liking or needing torque has nothing to do with what type of cam configuration or number of valves - the more cubic inches at low RPM produces more torque.
Look at a modern diesel like a Cummins 14 or Cat 3406 both examples of 4 valve heads where the more valves produced greater torque than the 2 valve head engines that they replaced (I know I'm dating myself to the 70's).
When you talk about Lexus, Ferrari or MB V-8's they are generally less cubes than a small block Chevy and you guys wouldn't put a SB in your 40' Skaters - right?
Also, look at the angles of the valves on a big valve push rod engine they are generally slanted as opposed to an OHC where the valve angles are flatter and two smaller valves make for better velocity than one large valve.
I studied all this in depth with the late Jim Fueling, his papers on valve geometry and flow are master peices but even he can't make low end troque without cubic inches.
HabanaJoe is offline
