Go Back  Offshoreonly.com > Owners Forum > Powerquest
A/c Unit For 38 Pq >
A/c Unit For 38 Pq
A/c Unit For 38 Pq
Old 05-29-2009 | 03:12 PM
Default A/c Unit For 38 Pq
Can anyone tell me the size of the A/C units (BTU's) that are in the 38 PQ's?
Also where are they located, are they under the V berth?
PWRQUEST is offline
Old 05-29-2009 | 03:29 PM
t500hps's Avatar
21 and 42 footers
I have a 7,000 in a 38 Formula. We've installed several 10,000's.....in a 37AT that is PLENTY!!!
t500hps is offline
Old 05-30-2009 | 07:31 AM
boathead's Avatar
I have a 2000, and it's underneath the hanging locker on the left, there is a screen right below the locker and behind it is the A/C unit.
Maybe the 01's are different. I hope you don't have to remove it , it's a pain in the a@s. I had to cut fiberglass to get it out last year, and then found out I could have just replaced the controller!!!!! Oh, it's a 7,000 BTU Marine Air
boathead is offline
Old 06-01-2009 | 09:00 PM
Under the v birth and easy to work on. 7,000
Dave Kline is offline
Old 06-02-2009 | 05:33 AM
For those you have installed in the v-berth (or other areas) can you post advice/description on how to run wirining, drain, seawater pump and vents?
Thanks!
Jeff
jeffgrice2 is offline
Old 06-09-2009 | 09:32 PM
performancemary's Avatar
Pressurized
I HAVE A 2001 AND ITS IN THE SAME SPOT AS BOAT HEAD, under the locker
boathead, WHWE DOES YOUR UNIT PICK UP WATER, MINE HAS A THROUGH HULL UNDER THE STEP TO THE CABIN, THE PUMP IS BEHIND THE REFRIFERATOR.
performancemary is offline
Old 06-12-2009 | 07:57 AM
boathead's Avatar
Pm,
My Thru Hull Is Just In Front Of The Port Engine, And Pump Is Directly Forward Of Engine Compartment, So I Have To Open The Hatch To Open The Seacock.
boathead is offline
Old 06-13-2009 | 06:09 AM
boathead,
So does your through hull also feed your pump out head?
I was wondering if I could pick up at the head for the AC instead of running another through hull?
Jeff
Old 06-23-2009 | 07:05 AM
boathead's Avatar
no, it uses freshwater from the tank
boathead is offline
Old 06-23-2009 | 08:45 PM
My ac and head draw through the same inlet through the bottom of the hull. It works fine.
Good Call is offline
