starter in 25 outlaw
Just disconnect wires and remove 2 or 3 bolts.To some one who has done it before they would probably say it's easy.To someone doing it the first time they may think it's difficult.If you do it make sure you disconnect the battery first!
I had the same issue, the click was coming from the port side of my engine on the top of the block (1999 454 MPI). Not from the starter location.
I removed the Mercathode blue box and below it was a slave solenoid.
Try jumping the two larger terminals with a screwdriver, if the starter engages it is the slave solenoid.
Just to make sure nothing is loose on the slave solenoid, disconnect the battery or else work real carefully.
Disconnect the two larger wires on the slave and check the tightness of the terminal studs for the wires you just removed.
They screw in, reattached the wires and tighten those nuts.
Hook up the battery and try again.
The whole procedure is a 10 min job working on the top of the engine, much easier than pilling a starter.
It is worth a shot, if the clicking sound is on the top of your engine.
Ken
Ken
Ken
Ken
