500hp with msd boxes ?? >
Old 05-31-2009 | 05:35 PM
Default 500hp with msd boxes ??
my 500hp i just refreshed and powered up are carb motors with msd boxes spinning 30 bravo 1 and it sounds like im in a revlimiter at wot at 5550 to 5600 if i back out a bit to 5300 or so all sound great. with the msd boxes do they overide the rev limiter or not ,,still stock ignition system and im thinking i need a bigger prop now.
rssteiny is offline
Old 05-31-2009 | 07:52 PM
MER Performance's Avatar
The Msd box will not over-ride the stock rev limiter, the marine box has it's seperate rev limiter that you add to it.
MER Performance is offline
Old 06-01-2009 | 12:50 AM
You rev limit had already been modified. The stock rev limit on HP500's is 5350rpms. I'm not sure what was changed originally to increase the rev limit.
Griff is offline
Old 06-01-2009 | 06:59 AM
I actually just got a response from joe that it still uses stock rev limiter, and im in it for sure so time to prop up.
rssteiny is offline
Old 06-01-2009 | 09:18 AM
in most cases, just being in possession of an MSD is like having a limit on your revs... often set at zero
stevesxm is offline
Old 06-01-2009 | 11:40 AM
wHAT DO YOU MEAN ??
rssteiny is offline
Old 06-01-2009 | 12:21 PM
He means the MSD boxes tend to go bad a lot.
Griff is offline
Old 06-01-2009 | 04:00 PM
Thunderstruck's Avatar
Rick,
what was your speed and avg rpm between the 2 motors?
Long time cult member.
Thunderstruck is offline
Old 06-03-2009 | 05:39 PM
Originally Posted by Thunderstruck
Rick,
87 at 5500 and in rev limiter hard, with 30 labbed bravo 1s, need a set of 32 to try, my prop slippage is high as well with the 30s.
rssteiny is offline
Old 06-04-2009 | 06:35 AM
yeap...MSD=may soon die
ezstriper is offline
