Wanted - 454 V8 Intake - OEM 811575T or 59974 >
Old 05-31-2009 | 08:05 PM
ljsmith1's Avatar
Default Wanted - 454 V8 Intake - OEM 811575T or 59974
I am looking for a good, USED, Intake manifold used only in fresh water, with minimal corrosion. I have to replace a salt water version on my '87 454 Alpha - on the cheap.
Please PM me with any leads.
Thanks!
-Larry
ljsmith1 is offline
Old 05-31-2009 | 08:35 PM
Default manifolds
I got a couple off a 420 hp Not sure of part num. but there alm. Tell me what to check for you and I will
redcorvetteman3 is offline
Old 06-01-2009 | 06:21 AM
Red, I believe with the alpha/454 combo they are all 330's with peanut port heads, your 420's are square ports.
Just a thought
prostock85 is offline
Old 06-01-2009 | 10:24 AM
ljsmith1's Avatar
Thanks, but Aluminum and Salt Water are not a good combo...
ljsmith1 is offline
Old 06-01-2009 | 08:41 PM
i have a freshwater use only off a 502 mag 1994 carb. i will get the part numbers but i think it is what you are looking for. pm me if interested
Fixxxer22 is offline
Old 06-01-2009 | 10:11 PM
original merc intakes on 370 and 400 motors in the 80's had a bronze water passages built into the aluminum intakes, not sure on newer ones
tms1155 is offline
Old 06-01-2009 | 10:17 PM
I should have a stock merc cast iron intake for a 454
with peanut heads. Fresh water use only,
looks like new.
$100 shipped in the 48 states.
email me
[email protected]
HTRDLNCN is offline
Old 06-11-2009 | 10:59 PM
Do you still need one?
getrdunn is offline
