Propeller Question
Old 05-31-2009 | 10:46 PM
Default Propeller Question
On a tripple outboards what would be the way to go with props? I was told the center engine you would put one size up from the outside engines.So Im running 2 28p bravo 1 and and ont the center engine would I go to a 30p bravo 1 or a
go smaller on the center to a 26p bravo1 ?
boating37 is offline
Old 05-31-2009 | 10:47 PM
My guess would be a 27 !!! ( 1 size down)
Because its deeper in the water and has more drag ???!!!
I may be wrong .
DareDevil is offline
Old 06-01-2009 | 12:27 AM
I may be wrong .
That sounds right to me also, but you really need go off the engine rpm.
You could probably also run a 1/4 smaller diameter center prop to pick up a little rpm on that engine.
Griff is offline
