need help jetting twin king demon's on 1271 >
Old 06-01-2009 | 08:59 AM
hoozeyurdaddy's Avatar
Default need help jetting twin king demon's on 1271
I'm having a hard time figuring out the jettng on this motor, 622 ci, 1271 blower, two king demon carbs, started off with 95 squared, seemed rich, whould come up on plane and not rev passed 4000 and it had a surge to it, fuel pressure is 7.5 and holding, put in 90 pri and 93 sec, won't even come up, timing set to 28 deg, on msd locked out, any recomendations???
hoozeyurdaddy is offline
Old 06-01-2009 | 01:27 PM
axapowell's Avatar
Where To
Get your tail pipes bunged and get a wide band O2 unit.
I have replaced my Holleys with Mighty Demon Marine carbs, and nobody could help me either. I bought a F.A.S.T. 2 channel System with 2 - O2 sensors. I can see what each bank is doing. My application is a N/A motor, but I started out with 85P and 93S. Ended up with 87P 95S. Still messing with it a little, but pretty happy (safe) here. Remeber, if you are NOT running power valves, square the jets. You can also call the Tech line, might find some insight there. Hope this helps a little.
Dave
axapowell is offline
