Do 502 MPI's have chokes? >
Old 06-02-2009 | 11:41 AM
Default Do 502 MPI's have chokes?
When my starboad is idling, it will sometimes jump up and idle fast around 1200. I goose the throttle and it will slow down to normal. Then sometimes it will just quit after it has been idling for a while.
Could it be the choke? Any other ideas?
jeff1000man is offline
Old 06-02-2009 | 11:50 AM
Fuel injected motors do not have chokes. They do have IAC motors (Idle Air Control).
jeffswav is offline
Old 06-02-2009 | 01:06 PM
the IAC duty cycle should be controled by ECT. when the engine is cold it should increase the idle slightly to get warmed up. that is the way it works on older gm fuel injected models. sometimes a biased ECT sensor can cause it to do that. or a sticking IAC valve can cause that also. not very fimilair with the marine setup but very fimilair with fuel injected vehicles. you can sometimes clean the iac with a wirebrush and some intake cleaner.
Fixxxer22 is offline
Old 06-02-2009 | 02:20 PM
ZXXX Donzi's Avatar
They also have cold start mode which makes them run rich at cool temps.
ZXXX Donzi is offline
Old 06-02-2009 | 08:28 PM
http://www.boatfix.com/merc/Servmanl/16/16cov2_1.pdf Save this you might need it some day
Boat Tech is offline
Old 06-02-2009 | 09:31 PM
And that is just the table of contents.
Old 06-02-2009 | 09:48 PM
Nope try opening some stuff up it should open it opened on my end, I tryd it before I gave it out, try some of the lower numbers on the left like number 11 for the bravo drive should open to, let me no, Also scrol down and find what you want and try to open the stuff in the black I just did and it opened up. Good luck with it, Iwas suprised to find some other engines and older drives stuff to open also, I found this on a different site they have others but no hi performance stuff. I am sorry I for got look for main menu at the top right corner in red then you will like it. That is way more then $70.00 manuals right there to save.
Old 06-02-2009 | 10:45 PM
http://forums.iboats.com/showthread.php?t=251571
Click on the link then right click on manual 16 save target as
diggster69 is offline
Old 06-02-2009 | 11:13 PM
Some of the manuals are not working over there But if you fallow some of the other guys post then I believe you can find away to open them up, But you need to read Don's read this post first from what I can see.
