Converting to Hydraulic Steering >
Old 06-02-2009 | 01:24 PM
Default Converting to Hydraulic Steering
It seems I have a mismatched hydraulic steering system. It has a Sauer-Danfoss /VERADO helm which is rated at 3.05 Cubic Inches of volume. The cylinder is and unknown brand...the pump is the factory GM pump on the engine. The problem is the cylinder takes too much volume for the helm. So it takes over 8 turns lock to lock.
I have already changed the helm to a faster unit...the fastest one I can get without changing all my hydraulic lines...and that helped a little, but only a couple turns....I was at 10 turns lock to lock before this.
So now I am thinking I need to get a faster cylinder. One that will move quicker with the helm volumn I have.
I need suggestions, I am open to anything except spending $1000s on a complete new system.
Here is a pic of the cylinder I have....anyone know who makes it?
agood1 is offline
Old 06-05-2009 | 08:23 AM
Registered User
That might be a Hynautic K5 cylinder.
Holeinthewater is offline
Old 06-05-2009 | 09:15 AM
northernoffshore's Avatar
Is that a balanced cylinder, a seastar helm would push that ram with out spending too much.
northernoffshore is offline
Old 06-05-2009 | 02:07 PM
Hang Time 27's Avatar
Looks like an old hynautic to me - I got two laying around. Sounds like the helm is the problem. Most of the used, inexpensive helms I have seen online and on e-bay are for inboard cruisers or outboards, with very small single cylinders, and will get you 8+ turns no matter what cylinder you use - the inboard cylinders are just that much smaller I guess. A buddy runs his donzi that way, with two hynautics out back, and 8 turns lock to lock - don't know how he stands it. Gonna need to find a helm meant for outdrives, which means the large cylinders - I was never able to find one used, without the whole system. New seems to be at least a $300 - 400 item, and might be your only option. Just my .02
Hang Time 27 is offline
Old 06-05-2009 | 02:11 PM
Registered User
That is NOT a balanced cylinder and so you can push that with any of the seastar helms except the pro models, but the seastar's largest model only pushes 2.4cu.in. per rev anyway.
Old 06-05-2009 | 03:52 PM
88Fount33's Avatar
Beak botr
That cylinder appears to have a very large piston and takes a large amount of fluid to move, it appears to be more like a heavy equipment cylinder whereas a typical Latham or Mayfair cylinder has a low volume to displacement requirement. Perhaps the helm and pump are sized well, just update the cylinder and you are golden.
88Fount33 is offline
Old 06-05-2009 | 04:00 PM
I have this helm for hynautic, but the threads for the wheel are damaged . used with the can.
Old 06-16-2009 | 03:07 PM
Steve H's Avatar
artselectricinc.com
Give Rik at Arneson a call. I bought a helm from him awhile back that was relatively inexpensive and it worked well on a ram about the same size as yours.
Steve H is offline
Old 06-18-2009 | 04:12 PM
PatriYacht's Avatar
A knowledgeable guy at a hydraulic supply store should be able to help you out. Hydraulic power steering is used on all kinds of industrial equipment. They tend to charge less than pure marine stores.
PatriYacht is offline
Old 06-19-2009 | 08:10 AM
My Cigarette Mistress has that same cylinders on it. I don't know what volume of oil it that to move it. All the older Cigarette's use them.
Harvey is offline
