need a little help
hello all, im new to the boating world. i just picked up a 81 sea ray 305. i/o i know its old but its in real good shape. i have put in a new starter,plugs,wires,cap,rotor,rebuilt thecarb,new coil,fule/water sep. i have gone threw this motor real good. i have been working on cars for a long time. but boats are new to me. ok now to my problem. it will turn over and fire and run for about 30 sec. if i keep giving it a little gas i can keep it running for a few min. but wont idle its almost like its running out of gas. it also did this befor i rebuilt the carb.i have played around with air fule mixture with no real changes. im kinda stuck. any one have any ideas?
Try turning up the idle screw until it stays running then adjust your idle mixture screws.If you can get them to a point where it runs smoother and faster then start turning down the idle screw.I'm assuming you have the timing set correctly.It could also possibly need a fuel pump.
bluez,have you tried a remote fuel can hooked to your fuel pump? There is also a check valve in the main fuel line between the pump and the tank that has been known to go bad before.Do you have a quadrajet on it??
yes it has a 4 b quadrajunk on it. i have tryed a remote fuel can.
