Need 2 Remote Oil Filters
I'm looking for 2 remote oil filter set ups. I have a TRS/454 set up with twins that originally had the filters on the blocks. So I need what ever it takes to plumb it for 2 engines.
Also looking for 2 top mount bell housing starters for TRS. Are these different than the under mount ones that mount on the block??
Thanks,
John
Thanks,
John
I did search it out last evening and found some other things I ordered as well. What should I do the "search" for on Ebay Motors??
Thanks,
John
PS I searched all BBC oil related products and didn't turn up what I was looking for. Any ideas...
Thanks,
John
Thanks,
John
I don't remember what color the anodizing is. I will have to check my stock.
Your block mount's will work, you will need to make new lines. THese are designed to mount on the back of the head.
I also have quite a few of the top mount cores. Some work, some don't they are not the same as bottom mount for bravo. You can have them rebuilt by any alternator starter shop.
Let me know what else you need, I have a bunch of old TRS stuff lying around that can get out of my shop real cheap.
