Wrench Size to Take off Oil Sender 454 >
Old 06-04-2009 | 09:42 PM
Default Wrench Size to Take off Oil Sender 454
I need to take off my sending unit so I can hook up a manual gage to verify if I really have an oil pressure problem or not. Sender has some rust and I don't want to strip it while I try to figure out what wrench size i need...9/16 is too big and 1/2 is too small.
Is it metric? I noticed what looks to be another sending unit next to the oil sender, is that for the low pressure alarm? Can I take it out and tap into it for the manual gage? What about one of the fittings on the remote filter housing, can I tap into that for a pressure reading.
redstinger is offline
Old 06-05-2009 | 12:00 PM
blue thunder's Avatar
9/16. Yes you could put it in the pressure switch location. I alway use the port on the remote filter housing for the mech gage.
blue thunder is offline
