stock exhaust to gil dry system >
Old 06-04-2009 | 09:51 PM
Default stock exhaust to gil dry system
Just put together a 496 stroker and picked up some gil manifolds with dry pipes i have 4 lines coming out of t stat housing is there any way to plumb the system with buying 2 60 doller y fittings , and Ive seen the manifolds plumbed 2 different ways first both hoses merge and go to bottom of manifold then jumper to riser , 2nd 1 hose to bottom of manifold and other merges with jumper which way would be better ?
stingray698 is offline
Old 06-04-2009 | 11:01 PM
The only other way is to run a T fitting at the riser. Thats what Merc did.
Attached Thumbnails stock exhaust to gil dry system-pantera-engine-02-t-fitting.jpg
Griff is offline
Old 06-05-2009 | 09:44 AM
where do you get that fitting at?
Old 06-05-2009 | 09:57 AM
I went to a plumbing supply store and got 2 brass t-fittings....Think they were 15 each. Its not a real fancy setup, but with some clever cutting and re-routing of the hoses, it works.
88Maxim is offline
Old 06-05-2009 | 10:00 AM
do you recall if that was 1 inch pipe or 3/4 thread size
Old 06-05-2009 | 10:07 AM
Off the top of my head 3/4" rings a bell, but im not certain. Im at work right now so im not able to check.
88Maxim is offline
Old 06-05-2009 | 10:14 AM
3/4" is correct, I am almost positive.
niceguy is offline
Old 06-05-2009 | 10:20 AM
Now im not so sure.........
http://http://www.cpperformance.com/detail.aspx?ID=661
88Maxim is offline
Old 06-05-2009 | 10:22 AM
also i ran into 1 other problem the nipple at the end of the pipe closest to exit is the water dump correct? i had to cut it off to get pipe through transom then heli arced it shut can i just cut another hole and put that fitting somewhere else? close to the end of the pipe
Old 06-05-2009 | 12:05 PM
3/4 NPT on the part that goes into the manifold and hose nipple on the other 2 ends. That is a factory Merc part. I actually just sold the set I had to Fixxer22. I'm not sure if he ended up using them. You could PM him. They are outrageously priced for new ones. I'm sure you could have a pair custom made also for a lot less.
Email Ken at http://www.offshorenortheast.com/
Griff is offline
