Old Fuel Question ????????
Had 1000 gallons of 93 octane delv to shop in may /o8 used about 900 gallons in the SKATER over a few weekend .. The kidz decided to use some of the last 100 gallons in there dirt bikes yesterday with 2 cycle of course and the YZ 85 & KX 250 lasted only 5 mins .... Can it be the old fuel ??? the YZ piston shattered & 250 will tear open today but can crank it over by hand and compression is gone ... these bikes ran thru winter & spring flawless till this tank of fuel... will drain the 125,450,& 500 this morning before any one starts them .. Same gas ,different cans due to mix ratios ... did put stabil in the 93 tank before winter ... any idears ???
Usually on 2 strokes, a failure like that is due to lack of oil. I would be really surprised if that was caused by the fuel, but what do I know?
It is easy enough to just get rid of the fuel and not take a chance. Sorry dude, that sucks.
Eddie
Eddie
When I first looked at your post I thought, well that fuel is only a month old. Then I looked at the year
. Dude, dump that fuel. I ruined the tops of my rod berrings in my boat a few years back. Most likley due to bad fuel. I was using E10 about 6 months old with stabilizer. Sorry about your bad luck, at least it was not in the boat. I have been told only to purchace the amount of fuel you will use in less than a month. Do some searches and you will find a lot of information posted hear. Give them a update when you find them and bring them back to the top. Maybe it will help someone else getting ready to make the same mistake.
good quality fuel in a sealed barrel will last a year easy. if the barrel is open to atmosphere it will get stale in about 6 mos... but having said that, i think eddie is correct... it sounds like lack of oil. when the fuel gets stale it just doesn't want to burn... nothing that i know or understand would suggest that it would cause detonation or lack of lube in a 2 cycle...
the evidence SEEMS overwhelming that it was the fuel but if that's true, i can't think of any factual based reasoning to explain it...
Hi! I tried to run 7 or 8 month old gas in my lawn mower this year and had to drain it out and put fresh in. It was 93 and had stabil in it, no oil mix. Was running pretty rough and rpm wasn't right then it died out. I knew it was the fuel right away and drained it before it screwed it up. Put fresh premium in it fired up and was good right away! It seems like the premium stays a little better then the regular so I run it even in the lawnmower. lol Good luck Charlie
they should be able to burn thru it in the pick up and the lawnmower
sounds like they should dump it all and use it for weed killer on the driveway
NO SMOKING !!!!!!!!!
