Is 20w50 Oil OK For A HP525 EFI? >
Old 06-08-2009 | 11:44 AM
Default Is 20w50 Oil OK For A HP525 EFI?
O Boy, another oil thread. The Mercury 25w40 is getting real hard to find around here but I can get the 20w50 Castrol GTX oil. Will this be OK? I've been told not to use synthetic in this motor to avoid valve train problems.
thirdchildhood is offline
Old 06-08-2009 | 11:54 AM
sure, vr-1 gtx kendall harley davidson oil... many opinions. you can check the marine lubrication thread. anayways i run the valvoline vr-1 20w 50. just my 2 cents. wesseldyke, who built my friends engines that run over 700hp N/A on pump gas has me run the gtx 20w-50 in his engines. so i would say you are fine
Fixxxer22 is offline
Old 06-08-2009 | 12:05 PM
lol, I started to look at the lube thread and there are like 5,000 posts. Thanks for the reply. I'll be changing the oil often.
Old 06-08-2009 | 03:28 PM
I have good luck with the Mobil 1 15/50, get it at Walmart in 5 Qt. jugs.
dslbrnr is offline
Old 06-08-2009 | 08:55 PM
I was told the Valvoline 20w50 race oil is a great oil to run in the 525. Especially the first couple of changes. Then sinthetic is fine, but not neccessary. I use the Valvoline and change every 25-30 hours.
redbud35 is offline
Old 06-08-2009 | 09:03 PM
I have used castrol 20w50 for last 2 years in 525's. No issues yet. Of course how do you know if its good oil unless you tear engine apart to look for wear after so many hours. change every season, 30-40 hours.
eeasy is offline
Old 06-08-2009 | 10:54 PM
seltzer's Avatar
Thats what I do.
seltzer is offline
Old 06-09-2009 | 08:18 AM
Thanks guys I will go with the 20w50 Castrol dino and change it often.
