Trailer Tire Pressure???
Old 06-10-2009 | 05:40 PM
Default Trailer Tire Pressure???
Whats the recommended tire pressure for a dual axel 12,000lb trailer?? 60-80lbs??
ActiveFun is offline
Old 06-10-2009 | 07:04 PM
Default Pressure
Depends upon Mfr. recommends usually 80 psi at that high a load.
Wannabe
wannabe is offline
Old 06-11-2009 | 04:41 PM
bowtie's Avatar
What tires? Load rating?
bowtie is offline
Old 06-12-2009 | 05:56 AM
mama tryed's Avatar
I usually run 5lbs less than what the sidewall says to allow for heat build-up.
mama tryed is offline
Old 06-12-2009 | 07:20 AM
Dock Holiday's Avatar
Charter Member #34
Under-inflation actually contributes to heat build up.
On a trailer I run the max that the tire shows on the side. In my case the tires are load range "E" and call for 80 PSI.
Check what's on the side of your tire.
Dock Holiday is offline
Old 06-12-2009 | 07:53 AM
dcb
Yes, read the tire pressure on the sidewall of the tire, like Dock Holiday said, under-inflation causes heat (tire flexing). Maximum inflation checked on cold tire.
dcb is offline
Old 06-14-2009 | 06:51 AM
mama tryed's Avatar
Being in the Tire Business, I'm just a little familar with under inflation, heat build-up, tread depth, section width, overall dia., rolling resistance, revs per mile,,, bla bla bla.
That 80lbs is the max inflation point, for that tire. FOR ME, I have found that 75 cold works the best, FOR ME, because it will be at the 80lbs, 150 miles down the road on a hot summer day.
Old 06-14-2009 | 03:34 PM
I run 75 psi on my MAX 80 psi tires also.
boatntrkr is offline
Old 06-24-2009 | 08:07 PM
masi242's Avatar
I just put new tires on the trailer today, I asked the guy and he said keep it at 35 to 40. I did not like that answer, that seems to low, max is 50psi so I will assume 45psi before I start the trip.
mark
masi242 is offline
Old 06-25-2009 | 12:11 AM
sleek1's Avatar
You mean to tell me the tire engineers don't take into account tire pressure increase due to heat when they stamp 80 psi max cold tire pressure on the side of the tire wall?
sleek1 is offline
