leak around raw water pump, HELP?? ?
Man, when it rains it pours!! I got the impeller changed, then fixed the alternator that got fried when boat took on water. I THOUGHT I had fixed leak, WRONG! I now have a leak around the inlet for the raw water pump. I checked the hose, the gear clamps, the gasket between the "elbow" and they are all dry, the leak appears to be "furthur back" down inside the drive somewhere? It only leaks while the boat is sitting (transom is subnerged) its not bad while underway. I am thinking of just trying to seal up the leak with silicone, any other ideas??
The marina I spoke to said it was a BIG job ($$$) to tear it apart and fix it, the boat sits on a lift in a boathousr, so, its OK there, but, wiuld like to anchor and not have the boat fill with water. I do have a bilge pump and float switch, but, if they ever failed I would be in a world of hurt.
Guys I am at wits end with this thing and would appreciate ANY and ALL input appreciated! THANKS!
Nivhael
Nivhael
Nivhael
Nivhael
Bellows is a new one, I have had a couple of people tell me its the drive seal, and/or the gimbal seal, either way, I have been told it wouldn't hurt anything (short term) what about trying to seal it up? It doesn't pour or spray in, its just a small trickle, but, over several hours it adds up. I have the boat high and dry now, so,I a. Thinking of trying to silicone it up tommorow, It can't make it leak any worse, just gonna be a nitemare to get to!
Any way to confirm and/or fix the bellows? Thanks for the input!
Michael
Michael
What kind of drive is it? I would doubt it is the transom seal. Could be the shift boot if it is a alpha or bravo, or they could have messed up the bellows and have a leak, it does happen.
Put your best foot forward!
I have had a couple of people suggest the swivel pin, its a closed loop cooled 454EFI with a Bravo 1 drive, as I said, it appears to be leaking around the inlet for the raw water pump, I checked the drive oil today and there is NO water in it. Any Thoughts? Thanks for the Replies guys!
My bet is the swivel shaft bolt . have seen this lots of times the bolt starts to rust and the seal starts to leak . A 5 cent seal a 3 hundred dollar bolt and a big pain in the ass to change. I have a freind that makes these bolts out of stainless , no more rust no more leaks. Just my .02 good luck Jeff
Hey Jeff
I have had a couple of people say that was the problem, around 2K to fix it, so, I am gonna try and silicone it up and get the summer out of it, hopefully it works?
I did notice some play "side to side" in the outdrive, I have heard this is an indication of pin wear
Foes your friend sell these pins/kis? Sounds like something I would be interested in buying, Thanks A Lot for all the help Jeff, and all other members as well!
Michael
Michael
The one BIG down side is that if the hole that was cut in the boat for the drive was not properly sealed up when new, It will soak into the treansom wood and make an even bigger expense !!!!!!!! several thou to fix a transom !!!!!! I dont think you can seal up a leaking swivel pin seal with RTV !!
RTV will not work because the pin moves every time you turn the boat. Like speedreeder said if this water gets into your transom you will be bumming WAY worse.
