Trim does not work when over 2,000 rpm >
Old 06-13-2009 | 08:24 PM
Default Trim does not work when over 2,000 rpm
Trim works good up and down when boat is on trailer or in water. But when it is on plan it will not go up. Trim pump runs but will not go up. Any suggestions would be great.
raymo1979 is offline
Old 06-13-2009 | 10:33 PM
Throttle Fever's Avatar
Cylinder orings bad. Do not have enough seal in the cylinders to over come the pressure of the engine pushing the boat. Guess?
Throttle Fever is offline
Old 06-14-2009 | 07:45 AM
Check and make sure the hoses are not reversed. I had same problem on a boat I bought from some dope. He had switched them when he put in new pump.
GoFastSonic is offline
Old 06-14-2009 | 09:17 AM
The hoses on the trim pump or the rams?
Old 06-14-2009 | 10:05 AM
onesickpantera's Avatar
My guess also. Or could be low on fluid.
onesickpantera is offline
Old 06-14-2009 | 05:46 PM
Thanks,Guys went out to day changed the hoses and wires going to the trim switch and it works fine.That is why the guy I got the boat from said it only went 85mph He must of not felt the bow digging in to the water.
Old 06-14-2009 | 08:31 PM
Lol I had same stupid problem Took me weeks to figure it out After I rebuilt trim cylinders and replaced the pump.
Old 06-14-2009 | 08:36 PM
Up north they always need longer Mike !!!!! LOL
DareDevil is offline
