26 Scarab Help
I have a 1996 26 ft. Scarab with a 502 that now has a B&M 250 blower on it. I run 5 lbs. of boost and should be making about 650 hp. I am running a Bravo 1 outdrive with a -2 Sportmaster Lower with 1.34 gears. I am using a 28 pitch Bravo 1 that has been lab finished. I have 2 problems that I need help with. First I can only turn about 4600 rpms. I think part of that is not enough carb for the engine which is being fixed. Second problem is that when I am cruising the starboard side lifts quite a bit. I have to run my port tab at about 3 to make the boat run level. Need some advise with all of this. Also tried a 3 blade prop for fun but was able to blow it out easily. It was a 25 pitch Mirage Plus.
502 with a 250 blower, you're gonna need at least a 1050 or 1150 Dominator Carb. I believe Mercruiser used 1050's on there 525SC which was basically a 454Mag w/177 blower. Sorry, don't know about your leaning.
I have the same boat - but with 502 mag (no blower
I have to drag the left tab also although only 1.5 -2. Running a Bravo 1 24p. Was running a 23p mirage and didn't lean quite as bad, although it still did some. Seems like these boats just like to torque over some.
)I have to drag the left tab also although only 1.5 -2. Running a Bravo 1 24p. Was running a 23p mirage and didn't lean quite as bad, although it still did some. Seems like these boats just like to torque over some.
